Evo još malo...ovaj nema štitnike za ruke
Manufacturer Suzuki
Model Year 2009
Model Burgman™ 400
MSRP $6,199.00
Engine 4-stroke, DOHC
Cooling Liquid
Displacement 400 cc (24.4 ci)
Bore x Stroke 3.1 x 3 in. (81 x 77.6 mm)
Carburetion Fuel injection
Compression Ratio 10.6:1
Ignition Electronic (transistorized)
Final Drive V-belt
Transmission Automatic
Suspension Front: Telescopic, coil spring, oil damped
Rear: Link type, coil spring, oil damped
Brakes Front: Disc, twin
Rear: Disc
Tires Front: 120/80-14 M/C 58S, tubeless
Rear: 150/70-13 M/C 64S, tubeless
Dry Weight 474 lbs. (215 kg)
Length 89.4 in. (2,270 mm)
Width 29.9 in. (760 mm)
Height 54.5 in. (1,385 mm)
Seat Height 28 in. (710 mm)
Ground Clearance 4.9 in. (125 mm)
Wheelbase 62.4 in. (1,585 mm)
Fuel Capacity 3.6 gal. (13.5 l)
Colors Gray, White
