Engine type: Single cylinder
Stroke: 4
Power: 21.00 HP (15.3 kW))
Compression: 10.5:1
Bore x stroke: 72.0 x 48.6 mm (2.8 x 1.9 inches)
Fuel system: Injection
Valves per cylinder: 4
Fuel control: SOHC
Starter: Electric
Lubrication system: Liquid
Cooling system: Liquid
Gearbox: Automatic
Transmission type
final drive: Shaft drive (cardan)
Clutch: Cradled in steel tubes with pressed steel
Physical measures
Dry weight: 123.0 kg (271.2 pounds)
Seat height: 780 mm (30.7 inches) If adjustable, lowest setting.
Overall length: 1,855 mm (73.0 inches)
Overall width: 740 mm (29.1 inches)
Wheelbase: 1,340 mm (52.8 inches)
Chassis and dimensions
Frame type: Cradled in steel tubes with pressed steel
Front suspension: Telescopic fork with Ø 35 mm
Rear suspension: Two dual effect hydraulic dampers, helicoidal spring adjustable to four positions
Front tyre dimensions: 120/70-12
Rear tyre dimensions: 130/70-12
Front brakes: Double disc
Front brakes diameter: 220 mm (8.7 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Power/weight ratio: 0.1707 HP/kg
Other specifications
Fuel capacity: 12.20 litres (3.22 gallons)
ista LEADER MAINA samo je dizajn novi nekima se sviđa nekima ne
