 Str: [1] 2 3 ... 16   Dolje
Autor Tema: Iron Butt to THE END, 10/10ths & Gibraltar to North Kappe in 3 days 28.05.2011  (Posjeta: 15347 )
tonci
  • Postova: 938
  • Vozi: ZZR,GTR 1400.
Ova tema je originalno bila zamisljena da se odvozi 10000milja (16000km) u 10 dana.
Nakon dosta studiranja,razmisljanja i vaganja, a i trazenja dozvole od Iron Butta dosao sam na ideju da bi mogao odradit voznju Giblatar to North Kappe u 3 dana zajedno sa ovom 10/10ths jer kad se kilometri zbroje ispada tocno 16045km sto ovo cini izvedivim ali na rubu moguceg jer zahtijeva vrhunski tajming i organiziranost.
Iron butt je dao zeleno svjetlo i rekli su da ce certificirat obe voznje mada to nerade, ali kad se ovako dvi velike voznje medusobno spoje da nema problema.
Uskoro cu stavit izmjenjene karte i sve sto ide uz rutu.
Na 4 strani se mogu nac stare mape sa vremenima i ostalim detaljima puta
nove su na 3 strani, po danima
Cijela ruta za GARMINA na 15 strani
The 10/10ths certification recognizes a ride of 10,000 or more miles in 10 days.
Before you can apply for a 10/10ths certification (10,000 or more miles in 10 days), you must have at least completed one of the following; a Bun-Burner GOLD, a SaddleSore 2000, the Alberta 2000, Capitol 1000, Nevada 1100, Minnesota 1000, TimberButt, Tarbutt Rally, Utah 1088, any Cognoscente Group event, any Reno BMW Long Distance Event, any MERA event, or the Iron Butt Rally. Other 24 and 36 hour rallies qualify. Their omission here is not intentional, it is just not possible to list all qualifying rallies. If you are unsure if a rally you finished is acceptable, please contact Michael Kneebone.
As this is an advanced ride, this is a certification program only (certificate only) and does NOT include a pin or plate back as it is assumed you have these items by now. Additionally, before attempting the 10/10ths, you must be familiar with the general documentation rules for Iron Butt Association certifications. The best resource for that would be a SaddleSore 1000 application. The SaddleSore application is located at www.ironbutt.com/rides/ss1000.htm You must also be aware of your odometer error. Even a small 2% error becomes critical on a ride of this magnitude, adding 200 miles to your required odometer reading. Finally, you must assess your risk. As outlined in the SaddleSore 1000 application, if riding a motorcycle 1 miles is X times the risk, and a SaddleSore is 1000x times the risk, than the 10/10ths is 10,000x the risk of a one mile ride! Do not underestimate the difficulty of the riding so many miles in so little time.
Generally speaking, documents that should be provided are:
1. Witness forms. We absolutely require a start and end witness form, but along the way, we recommend you obtain additional witness. For example, if you are riding the USA Four Corners Tour at the same time, a witness for each corner of the country would help enforce your claim that you did the miles claimed. Another good time to snag a witness is during any repairs, tire changes or oil changes you might make during the ride.
2. Records. You must keep a log of all gas stops and all gas receipts. Keep in mind that we have taken this ride, so we realize that this is a massive undertaking (both riding and record keeping!). There are two types of receipts, one that proves you really went to your location and the other is more supportive and therefore less critical. While you do not want to lose ANY receipt, the loss of one that is along your main route is not critical to our verification process. If you should lose a receipt, or could not get one in the middle of Nevada at 2 a.m., please document the situation in written form on your application.
Other records we want are: motel receipts, repair records and toll receipts. Obviously, any additional records that boost your claim are acceptable.
3. Application form. The following form lays out other information we need.
« Zadnja izmjena: 21. Lipanj 2011, 07:58:51 tonci »
Against all odds-Iron Butt
prof.
  • Postova: 102
  • Vozi: Kawasaki ER-5
  • Lokacija: Croatia
Odg: IRON BUTT to THE END
« Odgovori #1 : 07. Srpanj 2010, 12:54:32 »
Već vidim, hrpa forumaša (i ja među njima) sjedi pred ekranom i prati točkicu deset dana...  :palacgore:
Um je poput padobrana - funkcionira jedino ako je otvoren.
Albert Einstein
Doc Luka
  • Postova: 605
  • Vozi: Honda CBF - n 600
  • Lokacija: Jarun, ZAGREB
« Odgovori #2 : 07. Srpanj 2010, 14:21:12 »
 Ne  vidim svrhu  u  jačanju guzice  i  pražnjenju  džepa  i mozga  :misli:
Dr. Luka
www.docriders.hr
Prodajem hondu CBF 600 N  2007 g 32 000 kn
Author
  • Postova: 753
  • Vozi: Dječja kolica
  • Lokacija: u zavoju
« Odgovori #3 : 07. Srpanj 2010, 23:25:44 »
tako je  :mrgreen:  :palacgore:
Remember the past, plan for the future, but live for today, because yesterday is gone and tomorrow may never come.
tonci
  • Postova: 938
« Odgovori #4 : 08. Srpanj 2010, 01:21:42 »
Pozdrav.
Ako te vise interesira o ovome i o organizaciji, svrhu mozda mozes naci na njihovim stranicama.
Mnogi su napisali knjige o tome, a mozes i poslat mail predsjedniku asociacije pa pitat, ljudi ce sigurno odgovorit najbolje sto mogu.Imaju prilican broj clanova pa ce valjda neko dat prihvatljiv odgovor.
Ako kako osobno mogu pomoc rado.
rodorodo
  • Postova: 329
  • Vozi: ponekad
« Odgovori #5 : 15. Srpanj 2010, 09:24:12 »
Mislim da svaka osoba ima drugačiji film. Svakoga nešto pali: auti, motori, gliseri, paragliding, ronjenje itd...Ali najvažnije je da se ne sjedi doma sa daljinskim u ruci ili u birtiji od 0-24 i ispijati pivu. :palacgore:
tonci
  • Postova: 938
Odg: IRON BUTT to THE END, 10/10ths
« Odgovori #6 : 15. Srpanj 2010, 10:06:22 »
Je u pravu si i slazem se sa tobom.
Ove duge voznje i svo to vrijeme na motoru,gdje si prakticki sam zarobljem sa kvalitetom vlastitih misli koje ti prolaze glavom, pitas se mnogo toga i na kraju dodes do nekih spoznaja koje ispunjavaju na razne nacine sad da ne pilam previse.
Uglavnom samo dobivas, negubis i vrijedno je toga, a lipo je kad znas da postoje istomisljenici,je da su malo daleko ali su tu i salju certifikate!!!
Ljudi kako bilo,otvorio sam ovu novu temu jer sam se poceo pripremat za ovaj poduhvat 10 dana 16000km gdje cu provat s ovim ostvarit jos neke certifikate koje nude u iron battu,kao sto su 3000milja u 48 sati.
Nadam se da cu se dobro pripremit jer ovo dosad je bilo na neki nacin stepenasto napredovanje ka onome sto normalno sljedi,jer za ovo 10/10ths pise u samom praviliniku da morate imat barem 1500+ bun burner gold ili 2500+km u 24 sata nabrajaju oni jos toga,posto sam udovoljio uvjetu,odlucio sam se pokusat to odvozit.
Potrebna je odlicna organizacija i odlucnost da bi se to ostvarilo jer ipak je to 10 dana uzastopce vozit dnevno 1600km.
Neznam sto ce bit ali vjerujem da ce bit zanimljivo,opet cu pokusat sredit satelitsko pracenje i ako je moguce ubacit jos koju novotariju da bude interesantnije.
Nadam se da cu uspit.
Doc Luka
  • Postova: 605
« Odgovori #7 : 15. Srpanj 2010, 12:36:58 »
Against all odds  inače  je  jedan  film  85 g. snimljen.
Mislim  da  češ se  vozit  puno preko  ograničenja da  češ  biti  izmoren i  nečeš  moći  biti sabran cijelo  vrijeme a to  povlači  i  veće  šanse  za nekom  nezgodom. Tu  ti  ja  nebi  imao milosti.  Moja  mišljenje stoga da bi  imao  jedan  certifikat  više  :palacdolje:
Dr. Luka
www.docriders.hr
rodorodo
  • Postova: 329
  • Vozi: ponekad
« Odgovori #8 : 15. Srpanj 2010, 18:33:23 »
tonci samo gas, pamet u glavu i tvrdu guzicu haaa....haaa...
U životu je važno imati cilj pred očima, stoga  :palacgore:
tonci
  • Postova: 938
« Odgovori #9 : 15. Srpanj 2010, 21:50:09 »
Jedini problem a i malo ce duze trajat voznja je ovaj sjeverniji dio rute od stockholma do helsinkija ili obratno jer se mislim uputit mozda istok zapad da ovaj tezi dio bude prvi a onda je sve lakse posli stockholma prema lisabonu i nazad.
Je bit ce tesko i zahtijevno ali zato to i nije za svakoga,ja jos neznam dali je za mene ali do sada je bilo ok.
Nisam htio pisat da ovih 3200km u jednom smjeru mi nije prestavljalo super veliku teskocu,jer ionako kad nesto takvo spomenem ljudi mi nevjeruju,a nisu mi vjerovali ni kad sam sve ovo poceo,tako da mi je tvoj komentar vise nego poznat.
Bilo bi mi drago da imam podrsku sa strane sto vecu tim bolju, a ako nebude onda kao i uvijek kad si prvi u necemu vecinom si usamljen pa i u podrsci.
tonci
  • Postova: 938
« Odgovori #10 : 15. Srpanj 2010, 22:00:06 »
Mozda i manje!!!!
  • Postova: 14704
« Odgovori #11 : 15. Srpanj 2010, 22:14:39 »
ne sanjam o iron butt-u .... ali se volim voziti i na duže ture ... no, tko zna, možda i sam poželim jednog dana dobiti ovu laskavu titulu ...  :palacgore: :palacgore:
Moju podršku (bar preko foruma) imaš ...  :palacgore: :palacgore:
rodorodo
  • Postova: 329
  • Vozi: ponekad
« Odgovori #12 : 15. Srpanj 2010, 22:59:39 »
Imaš i veću podšku nego što misliš. Ljudi su pomalo skeptični, pitaju se čemu to? zašto, kakav je cilj toga itd...Dosta njih nemože shvatiti?
Zašto ljudi plove sami oko svjeta? jdrilicama? gliserima?
Zašto se pješke ide preko sjevernog i južnog pola?
Zašto se bez kisika penju na krov svijeta?
Zašto se sa balonima na helij ili na breneru penju što više i što dalje itd.....itd.....itd.....
U svakom slučaju svi koi su ovo pročitali budu te cijelo vrijeme pratili a i putnika koi ide Pan-amerikanom.
Samo znam proljetos kad sam se vračao iz Istambula za Zagreb, prejahao sam 1370 kilometara u komadu, (na skuteru Nexus 300) guzica je bolila još 2 dana. Jedino šta sam si u Turskoj poželio je HAJABUZU da stgnem što prije doma. Dobro Hajabuzu si nisam kupio ali skuter sam prodao i kupio Yamahu.Sad je puno brže.
Možda bude problema sa 1600 kilometara svaki dan pogotovo kad upadneš u gužbu (problematična mjesta) Paris, Belgija, ulazak u Njemačku, Bremen, Hamburg.
A naprimjer relaciju Berlin- Zagreb budeš preletio, dobra cesta i svaki radar te bude slikao i probudio. Možda glupo zvuči za nekog sa strane.? Poslovno sam išao u Berlin autom i isti dan sam se vratio nekih 2400 kilometara, cijelo vrijeme nisam vozio ispod 200 osim tuneli i velika križanja i mogu reći nije me umorilo, ali znam to je auto nije motor.
Tek sad sam vido da ti ruta ne vodi direktno za Zagreb, nego prema Švicarskoj, isto dobra cesta. Samo se pazi u Njemačkoj  (autoban polizei) da ne gubiš puno vremena na presretačima.  :palacgore:
tonci
  • Postova: 938
« Odgovori #13 : 16. Srpanj 2010, 00:19:23 »
ma moje su brzine mx 160 jer sve vise je bezpotrebno.
tako da nece bit problema
pelizzari
  • Postova: 109
  • Vozi: atlantic 250, GS 500
  • Lokacija: Biograd na Moru
« Odgovori #14 : 16. Srpanj 2010, 09:49:47 »
nisan ni sumnja da ćeš stati samo na jednom prišivku  :wink:  8)
podršku u svakom slučaju imaš  :palacgore: :palacgore:
e sad, da li več imaš u planu kad bi se krenulo  :palacgore:
tonci
  • Postova: 938
« Odgovori #15 : 16. Srpanj 2010, 14:19:59 »
dogodine 05 ili 04 misec ali prije 05 nadam se,moram se jos bolje pripremit i organizirat,mozda bi snimio dokumentarac o tome pa sam jos u nekim zacecima ideje kako bi to trebalo bit.
Pokusat cu nac sponzore,ali prvo cu sastavit cijelu pricu o tome i ponudit nekome.
Sa ciljem da pokrijem osnovne troskove ako uopce budem mogao.
vidjet cemo, ali datum je definitivno dogodine u 05 misec.
tonci
  • Postova: 938
« Odgovori #16 : 24. Srpanj 2010, 13:01:05 »
Mozda dotada se nade neko pa budemo vozili skupa,mada je to i opasno jer koliko bi gurali jedan drugog toliko bi i kocili tako da to ima svoju dobru i manje dobru,necu rec losu stranu.
mv_agusta
  • Postova: 5424
  • Vozi: nexus500
« Odgovori #17 : 25. Srpanj 2010, 10:13:26 »
tonci samo naprijed :palacgore: :palacgore: i pazi u skandinaviji na policiju ili glumi ghostridera :jesus:
Ride Hard, Ride Free
Anton
  • Postova: 445
  • Vozi: Suzuki GS 500 '92. & GSX 750F '90.
  • Lokacija: Vinkovci
« Odgovori #18 : 25. Srpanj 2010, 12:06:10 »
Tonči, imaš moju podršku, svaka čast na poduhvatu. :palacgore:
Što se tiče ovoga, zašto to netko radi...Ah, kao što je već napisano, ljudi svašta rade, pa se ne treba čuditi. Ovo je baš pravi test izdržljivosti, jer prelaziti 1600 km dnevno je stvarno - puno. Ako se želiš koliko-toliko naspavati i odmoriti, srednja brzina bi ti trebala biti cca 120 km/h, što je 13 sati putovanja dnevno. Taman da staneš jesti i popiti nešto, i odspavaš onih 8 sati koliko je čovjeku u prosjeku potrebno. U svakom slučaju zanimljiv poduhvat, ali i jako naporan, psihički i fizički.
Sretno!
japanska mašina, od petsto kubika, kad je vozi Balkanac, pravi mačo muškarac
tonci
  • Postova: 938
« Odgovori #19 : 26. Srpanj 2010, 01:18:45 »
kad sam poslao mail i pitao sto je najteze za uradit a oni najvise rangiraju rekli su mi da je 10/10ths najteze, a da postoji nesto jos teze ali da mi ne savjetuju to radit prije ovoga, a to je dva bun burnera gold jedan za drugim, to je ako gledas na njihovim stranama 3000milja u 48 sati i teze ne postoji.
Ove 4 discipline ili voznje, nazovi kako hoces Bun Burner gold 1500+ milj u 24h, 2500km u 24h,10/10ths i 3000mil u 48h su najjace i najextremnije voznje koje se mogu odvozit a nespadaju pod ameriku.
Meni je cilj to odvozit.
Naime planiram kad (Ako???)  dodem do Lisabona, odvozit do splita bez stajanja,po ruti koju sam stavio to je preko barija oko 5000km (3000mil je 4800km) znaci da bi ja udovoljio tome.
Tako da bi odvozio te dvi discipline zajedno.
Da ce bit naporno,bit ce prenaporno i treba se vrhunski pripremit kako fizicki tako i psihicki.
Tocno odredit stajanja,sto jest kad jest,izracunat kad krenut,koliko vremena za spavat,ma aba bas sve znat unapred.
Sa pripremama sam krenuo a kako budu tekle, informacije cu stavit ovde.
Pokusat cu nac neke sponzore jer je projekat zahtijevan i financijski.
tonci
  • Postova: 938
« Odgovori #20 : 26. Srpanj 2010, 06:57:04 »
Evo smjernice i savjeti koje daju u Iron Butt organizaciji i uopce nisu losi dapace covik moze nesto i naucit od toga.
Da samo vidite o cemu se radi i koliko su to odgovorni vozaci prema sebi a i drugima.
http://www.ironbutt.com/tech/aowprintout.cfm
tonci
  • Postova: 938
« Odgovori #21 : 26. Srpanj 2010, 07:51:15 »
2.   Forget about high speeds.
Forget what you've been told; high speeds and long-distance riding have little in common. A steady rider can book more miles, enjoy more mountain vistas and ride more twisty miles than a canyon carver bent on making the best times across a mountain pass. Besides the obvious effects on fuel mileage, which means more time wasted looking for gas, and the fatigue caused by fighting the effects of pushing a motorcycle through the wind, riding much beyond the flow of traffic will land you a hefty speeding ticket. While you are on the side of the road having a spirited discussion with a Police officer about your 10/10ths riding style, the turtle-like rider on the Honda 250 will wave as he sets himself up for the next set of corners.
Ovo je sto kaze udruzenje tako se i ravnam!!!!
Author
  • Postova: 753
« Odgovori #22 : 26. Srpanj 2010, 10:29:27 »
ali si broj 3 daleko prekršio da ostaneš budan :mrgreen:  :palacgore:
Citat:
3. Leave your drugs and coffee supply at home.
It's this simple, drugs and other stimulants do not work! If you need No-Doze or other drugs to stay alert (the Iron Butt Association includes coffee and colas on this hot list), it's time to stop for the day and get some serious rest.
Doc Luka
  • Postova: 605
« Odgovori #23 : 26. Srpanj 2010, 13:58:21 »
Da  i  tko  te  može  kontrolirat ?  možeš  se pucat  injekcijama steroida/ hormona
Dr. Luka
www.docriders.hr
Author
  • Postova: 753
« Odgovori #24 : 26. Srpanj 2010, 14:48:25 »
ja ga ne optužujem, samo kažem kroz šalu, ako nije zabranjeno neka se održava sa kofeinom budnim i ok, a da je zabranjeno vjerovatno bi tražili nalaz krvi od tog i tog datuma kao dokaz ili neka slična šema
 Str: [1] 2 3 ... 16   Gore
Stranica je generirana za 0.158 sekundi uz 16 upita.
