 Str: [1] 2 3 ... 6   Dolje
Autor Tema: pegaso 650 - 2000 god - pitanja  (Posjeta: 4108 )
zwer_1982
  • Postova: 192
  • Vozi: Aprilia pegaso 650
  • Lokacija: 45.616503,15.32398
« : 05. Svibanj 2011, 15:17:38 »
Planiram sam mijenjat ulje na pegasu 650, 2000 - ta godina. Odvezal bi ga u servis ali financije ne dopuštaju  jel...
Da se razumijemo nisam neki antitalent za mehaniku, dosta se razumijem i dosta stvari znam sam napravit jer stalno šerafam po nečem.
Nemam niti ovdje nekih problema jedino me malo buni dvostruki smještaj ulja ( rezervoar kod volana i u motoru) jer su sve mašine po kojima sam šerafal imale samo ulje u motoru i cijeli posal oko ispusta ulja bi se svodil na ispuštanje ulja iz kartera.
Našal sam jedan link u kojem je sve skupa dosta dobro objašnjeno međutim ako ima neki link sa slikama bio bi jako zahvalan da ga netko stavi.
http://www.apriliaforum.com/techtips/650/oilchange.htm
1. Warm engine for at least 10 minutes or 10 miles. Place vehicle on center stand.
2. Remove lower plastic skid plate to gain access to engine oil drain plug.
3. Place oil catch pan under the engine and remove the oil drain plug. Inspect drain plug gasket for nicks, replace as necessary. The drain plug is located on the bottom of the engine case.
4. Allow all the oil to drain out.
5. Just behind the front wheel is a secondary oil drain plug. This plug drains the oil tank since this is a dry sump oiling system.  It looks like a spigot attached to the frame.  Use caution here! The oil comes out hard and fast, and will completely soak the back of your front tire with oil.  Hold the drain pan up to the spigot to catch the oil. Allow all this oil to drain.
6. Remove oil filter cover by removing two 5mm head Allen bolts.  The filter cover is located on the right side of the motorcycle just forward and above the countershaft sprocket cover.
7. Pull out filter and replace with new filter. Replace cover and tighten the two bolts.
8. Replace both drain plugs and tighten.  The engine oil drain plug should be 28.9 ft-lb tight and the frame mounted oil tank spigot drain plug should be tightened to 15.9 ft-lb.
9. Pour about 1.69 Qts (1.6L) of clean new motor oil into the oil fill/dipstick located just in front of the gas tank.
10. Start the engine and let idle for one minute.
11. Add an additional 0.63 Qts (0.6L) of oil.
12. Start bike and let fully warm up. Ride the bike 5-10 miles.
13. Recheck oil level, fill as necessary.
14. Dispose of used engine oil and filter properly.
« Zadnja izmjena: 23. Svibanj 2011, 09:51:00 zwer_1982 »
Zubakis
  • Postova: 173
  • Lokacija: 7K
Odg: pegaso 650 - 2000 god - promjena ulja
« Odgovori #1 : 05. Svibanj 2011, 20:14:29 »
Evo ti privitak (attachment) u pdf-u sa slikama. Nadam se da će ti biti od koristi.
biso1
  • Postova: 303
  • Vozi: gsx750f
« Odgovori #2 : 05. Svibanj 2011, 20:47:51 »
nije niš komplicirano, ispustiš ulje na šarafiću sa prednje strane rame, odmah ispod kilera i onda na šarafu ispod motora. odšarafiš dva imbus šarafića sa filtera ulja, primineiš filter i sve ponovno sastaviš. uliješ ulje kroz čep na rami, al ti najveroajtnije ne bu stalo odmah sve, zapališ motor na kratko da ventil propusti ulje i nakon toga natočiš ostatak. to ti je ovak u grubo, ak ne treba nekaj detaljnije delat i bilo bi poželjno promijenit one bakrene podloške da ne propusti ulje kad zašarafiš šarafe za ispust.
biso
Zubakis
  • Postova: 173
  • Lokacija: 7K
« Odgovori #3 : 06. Svibanj 2011, 08:38:33 »
Šta će minjat ulje ako će na kraju zapalit motor.  :LOL:
NHF :palacgore:
zwer_1982
  • Postova: 192
« Odgovori #4 : 06. Svibanj 2011, 09:42:43 »
thx
u pravilu imam običaj uvijek stavljat nove bakrene podloške di god mijenjam ulje ;) (auto traktor, freza....)
thx na savjetu
@ Zubakis: thx na manualu :)
zwer_1982
  • Postova: 192
« Odgovori #5 : 06. Svibanj 2011, 09:46:00 »
još nešto, može preporuka ulja?
Negdje sam čital da ide polusintetika 10-50W, kak sam trenutno u financijskoj stisci a motor nemogu doma gledat i ne vozit se, jel mogu stavit kao privremeno rješenje neko 10w-40 ulje tipa shell ?
biso1
  • Postova: 303
  • Vozi: gsx750f
« Odgovori #6 : 06. Svibanj 2011, 10:39:59 »
Ja sam u svog stavio sad nedavno motul 15w50, nekih 80-ak kn po litri
biso
biso1
  • Postova: 303
  • Vozi: gsx750f
« Odgovori #7 : 06. Svibanj 2011, 10:41:41 »
NHF :palacgore:
Pa bolje gori sa novim uljem :mrgreen:
biso
Makki
  • Postova: 437
  • Vozi: Lancia Delta II 1.8VVT ,NRG 180,
« Odgovori #8 : 08. Svibanj 2011, 21:05:20 »
Preporuka je 15w50 ulje
Speed is just a question of money.......How fast do you wanna go??
SERVISIRANJE SVIH VRSTA SCOOTERA I MOTOCIKALA
DaRRth Vader
  • Postova: 2259
  • Vozi: YAMAHA STRIKES BACK
  • Lokacija: Down Under
« Odgovori #9 : 09. Svibanj 2011, 06:57:56 »
  :palacgore:   To je preporuka za uništiti spojku anlasera  :mrgreen:
5W 40 je ulje za Rotaxa
zwer_1982
  • Postova: 192
« Odgovori #10 : 09. Svibanj 2011, 08:24:20 »
sad više ništa neznam, koje ulje ide na kraju?
dannyghost
  • brišem sa i bez veze
  • Postova: 1489
  • Vozi: kiLLeRR - gazim po želji
« Odgovori #11 : 09. Svibanj 2011, 08:28:39 »
prati  ...........
serviser zna  :palacgore:
ljetovanja i rad na plantaži bannana sa Moderator Airlines
"LJUDI, ja sam zaista životinja, samo što sam lijepo odjeven", rekao je Mike Tyson
Zubakis
  • Postova: 173
  • Lokacija: 7K
« Odgovori #12 : 09. Svibanj 2011, 08:30:56 »
U manualu piše 5W-40 pa sad gledam i ja šta pišete 10W-40 ili 15W-40.
S obzirom da je DaRRth Vader alfa i omega za Apriliu ja tu nemam šta nadodat. Slušaj čovika i nečeš falit.  :palacgore:
zwer_1982
  • Postova: 192
« Odgovori #13 : 09. Svibanj 2011, 11:18:37 »
OK
sa savjetina priznetih servisera nemam dilema, znači 5-40 ide unutra.
Nego da li je jako bitno da to bude neko moto ulje ili može i neko brand auto ulje - imam doma mobil i castrol 5-40 za auto?
Zubakis
  • Postova: 173
  • Lokacija: 7K
« Odgovori #14 : 09. Svibanj 2011, 13:58:48 »
OK
A prijatelju ti bi najradije da ti mi rečemo da može sojino ulje, pa da ga možeš doma maznit iz kuhinje.  :LOL: :LOL:
To je 2,2 litre ulja. Kupi kako triba ili ne vozi.
zwer_1982
  • Postova: 192
« Odgovori #15 : 09. Svibanj 2011, 14:55:49 »
Ok, kupujem po prepuruci, nema potrebe za podje.......
Makki
  • Postova: 437
« Odgovori #16 : 10. Svibanj 2011, 00:36:30 »
Buš kada navratiš onda Akiu istrljao uši  :mrgreen: mene su ismijali ,a radio sam sa Rotaxom i ZNAM da je 5w kod njih ZAKON ali eto AKI je kriv sunce mu
DaRRth Vader
  • Postova: 2259
« Odgovori #17 : 10. Svibanj 2011, 06:22:13 »
ne dirajte mi AKIJA  :wink: :box: :box: :box:
Makki
  • Postova: 437
« Odgovori #18 : 10. Svibanj 2011, 19:10:35 »
hAHAHAHA znači pod tvojom je zaštitom, zato je tak bahat od kas si mu bliže  :LOL:
zwer_1982
  • Postova: 192
Odg: pegaso 650 - 2000 god - pitanja
« Odgovori #19 : 23. Svibanj 2011, 09:57:01 »
evo motor je konačno doma.
Danas pokupim ulje i filtere i mijenjam. Neki motul 5w-40 4T je u igri. Jel to to?
Nego imam pitanje, prokužio sam da mi na ležaju volana ima malo lufta, na koji način se doteže ležaj?
Sljedeće: Kod gašenja dosta se čuje onaj povratni metalni udarac, bojim se da bude i bendix trebalo uskoro slagat. Može preporuka člana ili majstora da mi to pogleda pa da saniram ili spriječim veliki trošak ako nije već pre kasno?
danijel044
  • Postova: 278
  • Vozi: Bmw f650gs
  • Lokacija: Sisak
« Odgovori #20 : 23. Svibanj 2011, 10:33:41 »
Čim se čuje taj udarac znači da je nešta već dobilo po piksi....možda samo "ležaj"  ,a možda i kućište.  :palacdolje:
Uglavnom nešta od ove ekipe na slici   :?
zwer_1982
  • Postova: 192
« Odgovori #21 : 23. Svibanj 2011, 11:00:20 »
čuje se udarac i kao da se od tog zavrte neki zubčanici, čuje se onaj šum...
zwer_1982
  • Postova: 192
« Odgovori #22 : 23. Svibanj 2011, 12:55:12 »
pronašao sam ležaj bendixa i to na njuškalu.
Jel to to što bi bilo pametno zamijenit?
http://www.njuskalo.hr/motori-dijelovi/pegaso-650-lezaj-bendixa-anlasera-cod-0958857-799kn-oglas-1363315
DaRRth Vader
  • Postova: 2259
« Odgovori #23 : 23. Svibanj 2011, 13:18:03 »
u zadnje vrijeme ležajeve mu ja prodajem ... :LOL:
380 kn i tvoj je... :mrgreen: :mrgreen: :mrgreen:
zwer_1982
  • Postova: 192
« Odgovori #24 : 23. Svibanj 2011, 13:23:16 »
wow :palacgore:
možeš i promijenit?
 Str: [1] 2 3 ... 6   Gore
Stranica je generirana za 0.136 sekundi uz 17 upita.
